Norton equivalent
Discussion in 'Homework Help' started by regexp, Dec 27, 2010.
  1. regexp
    Nov 20, 2010
    24
    I have the following circuit
    And i need to calculate the norton equivalent circuit.
    After i shorted the voltage source and changed the current source into an open circuit, the thevenin resistance R_{th} = 4ohm
    Applying the superposition principle the short circuit current is 2A plus the current generated by the voltage source. This is where i had to stop and think. Are there any current traveling through the 6ohm resistor?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes the current will be flow through 6ohm resistor.
    And how can 2A is short circuit current?
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Look at this diagram
  4. regexp
    Nov 20, 2010
    24
    Thanks, i didn't know you could add them like that.
    Is there any other way besides source transformation?
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, superposition also work very well
  6. regexp
    Nov 20, 2010
    24
    Hm, the only way i get 1A from the voltage source is
    if i consider the 6ohm and 3ohm resistor in parallel.
    \frac{6\cdot3}{6+3} = 2
    and then \frac{2\cdot2}{2+2} = 1
    However arent they supposed to be in series when the voltage source appear in between?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hmm, To find Norton equivalent
    First:
    Calculate the output current, IAB, with a short circuit as the load.
    Then find Rth
    Replace all voltage sources with short circuits and all current sources with open circuits.
    So first we need to find this short current by using superposition.
    I first remove the current source
    And then by inspection I write
    Isc1 = ( [ 6V/(3Ω||2Ω + 6Ω) ] * 3Ω||2Ω ) / 2Ω = ( (6/(1.2 + 6)) * 1.2 ) / 2 = 0.5A
    And now we replace voltage source with a short circuit
    Is2 = 2A * (6Ω||2Ω) / ( 6Ω||2Ω + 2Ω ) = 2A * 2/4 = 1A
    So our final solution is
    Isc = Ics1 + Isc2 = 1.5A
    and Rth= 4Ω
    And of course we can get the same answer with source transformation method, or nodal/mesh analysis .
  8. regexp
    Nov 20, 2010
    24
    Thank you very much. There is one part i don't really understand
    First, the total current is
    6V/(3Ω||2Ω + 6Ω) = 6/7.2 = 0.83A
    Then we use current division.
    3/(3+2) * 0.83 = 0.498A
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    You use current divider rule, but I use Ohms law.
    First I find total current
    Itot = [ 6V/(3Ω||2Ω + 6Ω) ]
    next I find voltage drop across 3Ω||2Ω
    V = Itot* 3Ω||2Ω =[ 6V/(3Ω||2Ω + 6Ω) ] * 3Ω||2Ω
    And finally, if I know the voltage across 2Ω resistor I can easily find current that flow through 2Ω resistor.
    I = Isc1 = V/2Ω = ( [ 6V/(3Ω||2Ω + 6Ω) ] * 3Ω||2Ω ) / 2Ω = ( (6/(1.2 + 6)) * 1.2 ) / 2 = 0.5A
    I hope you understand now.
    And maybe at the end I show how you can use nodal equation to find Isc
    for this circuit:
    2A = Va/6Ω + Vb/3Ω + Vb/2Ω (1)
    Vb - Va = 6V ----> Vb = 6V + Va (2)
    2 = Va/6 + 2Vb/6 + 3Vb/6
    2 = (Va + 5Vb)/6
    2= ( Va + 5*( Va+6 ) )/6= ( 6Va + 30) / 6
    2 = (6Va +30) / 6
    12 = 6Va + 30
    -18 = 6Va
    Va = -18/6 =-3V
    Vb = 6V + (-3V) = 3V
    And finaly Isc = Vb/2Ω = 3/2 = 1.5A
    So as you can see you can use any method you want to solve this circuit.
  10. regexp
    Nov 20, 2010
    24
    Very helpful, thanks :)
