Norton Equivalent
Tin Whisker
Joined Dec 3, 2008
8
Can anyone help with the attached circuit. I can't understand how to work it out!
I thought you had to turn the voltage source into a current source by dividing it by the nearest resistor? But someone else told me you don't........... :confused:
There's a beer in it for the most helpful person :D
The Electrician
Joined Oct 9, 2007
2,970
Show your attempt.
Convert the series combination of the 7 volt source and the 7 ohm resistor to a current source in parallel with a suitable resistor (that's what you will calculate).
Then what do you think you should do next?
Tin Whisker
Joined Dec 3, 2008
8
7 Volts / 7 Ohms = 1 Amp
The 1 Amp is now in parallel with the 7 Ohm resitor
Add the 1 Amp to the 6 Amps = 7 Amps
The 7 Ohm and 9 Ohm are now in parallel, so 7X9/7+9 = 63/16 = 3.9 Ohm Resistor
So the new circuit looks like this:
Now I would turn the current source back to a voltage and put the 3.9 Ohm resistor in series with the voltage source?
vvkannan
Joined Aug 9, 2008
138
You are right.A Norton's circuit consists of a current source in parallel with a resistor .So you dont need to convert it to a voltage source again
vvkannan
Joined Aug 9, 2008
138
No you should not remove it.Your answer is right.Just use current division rule and find the current through 3 ohm ( 7 x 3.9/(3.9+3))
chyadesh
Joined Apr 10, 2009
19
please..reply me if my answer is wrong..... I had a thought when we replace the network having 9ohms resistor with short circuit.. in my opinion the current source must be removed since short ciruited and the answer is 1.5 amps...neglecting the current source
