Norton equivalent help
Discussion in 'Homework Help' started by willhuang03, Nov 21, 2013.
  1. willhuang03
    Nov 17, 2013
    Hi all,
    I'm stuck on getting the right answer to the following problem:
    It's asking me to convert the right circuit into the norton equivalent.
    Here's the work that I've done.. but I can't get the right answer:
    http://s18.postimg.org/mntlo8fsp/my_attempt.jpg
    It would be great if someone can point me out where I went wrong.
    Thanks!
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    You start your analysis with the assertion that i2=0A. What is this based on?
  3. willhuang03
    Nov 17, 2013
    My thought process was that since the circuit was being shorted, that all the current will go through the short, and none would go down R3.
    But when I think about it again.. would the dependent voltage source generate a current through R3?
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    A reasonable, but wrong, conclusion. All the short does is impose the constraint that the voltage across it is 0V. It does NOT require that ALL the current go through it, just whatever current that must flow through it in order to impose the 0V constraint across it.
    Yep.
    willhuang03 likes this.
  5. willhuang03
    Nov 17, 2013
    Thanks for the help! The explanation really helped me clear up on alot of problems I have with Norton equivalents!
  6. shteii01
    Feb 19, 2010
    3,504
    512
    Do the Thevenin equivalent circuit. This will give you Vth in series with Rth. Then do source transformation, Vth with Rth in series becomes Current Source in parallel with Resistor.
