Noob Transformer question
Discussion in 'General Electronics Chat' started by cmac0351, Aug 18, 2008.
  1. cmac0351
    Jul 11, 2008
    7
    I have been looking for a suitable transformer for a project I am working on.
    Is there a difference when the primary and secondary impedance are listed with a "CT" after the number, as in 600:600 and 600 CT: 600 CT?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    CT is Center-tap. It is a winding with a center-tap that you don't need to use.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    While you may not need to use the center tap, it could open up other possibilities.
    A 600 CT: 600 CT could also be used as:
    300: 600 CT
    600 CT: 300
    So, you could double or half the output voltage, or simply match the impedance differently. It all depends upon what you need to do.
  4. studiot
    Nov 9, 2007
    5,005
    515
    Remember also that the 600 ohms or whatever is rated at the frequency of operation.
    You will not measure this with a DC ohmeter.
    Ohms law (AC version) then gives the normal current in any configuration you use.
