Noob needs help.
WTL75
Joined Oct 12, 2007
What would you recommend I use for a timer and relay for the attached circuit? The timer will need to use 110VAC and switch every 15 min. The AC and DC circuits need to be isolated.
Thanks in advance!!
TY,
WTL75
SgtWookie
Joined Jul 17, 2007
22,230
I'm curious as to what you're trying to do with that circuit?
I see you're switching between the + and - of the battery bank, but there is no path for return current.
How come you have five pairs of batteries in parallel? Do you really need that much current?
