Noob alert: Low pass audio filter help
Discussion in 'The Projects Forum' started by skase, Oct 14, 2008.
  1. skase
    Oct 14, 2008
    Hi everyone,
    I have very little electronics experience so be nice :)
    I'm trying to build a simple acoustic stomp box which takes an audio signal from a small piezo transducer, filters out all the high frequencies above say 150Hz and sends the output to a auido jack which is plugged into an amp. It's a simple device to replicate a bass drum sound commonly used in blues. (The transducer sits on the wall inside a hollow wooden box to amplify the sound of a foot taping on it)
    The circuit below seems to be what I'm after however my limited knowledge of this stuff has me stumped on a few (read most) things:
    1. What does the circle represent?
    2. Where exactly I would wire in the transducer and jack output? I'm guesing they sit in paralell with the unknown component but am not 100%.
    3. Would this need to be powered at all?
    4. If I wanted to adjust the cut-off to 150Hz what changes would I make.
    This probably seems pretty basic for you guys, sorry. Any diagrams (layman or otherwise) would be helpful. :D
    Thanks in advance!
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. skase
    Oct 14, 2008
    Thanks for the reply.
    Just so I'm clear then, the ground from my output jack would connect to point 0 and the active to point 2 on the right of the diagram.
    My transducer active wire would connect to point 1 and the ground to point 0 on the left. Then my ground connection can be anywhere along the bottom.
    And according to my calculations I need around a 150 ohm resistor in position R1 to give me my 150Hz cut-off.
    No additional power is required?
    Is this right? Cheers again.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Yes but i forgot to mention something about the cut-off frequency.
    It is equal to:
    f=1/(2*pi*(R1//Rload)*C1)
    R1//Rload means R1 in parallel with Rload
    so make your calculations again.
    Also, you have to take into account how much current the output of your pick up can source/sink as not to burn it. Do you have its specifications?
