Nonoverlapping clock generator
Discussion in 'The Projects Forum' started by andrea86, Sep 30, 2010.
  1. andrea86
    Sep 30, 2010
    12
    Can anyone help me with nonoverlapping clock generator?
    Why are these clock nonoverlapped?
    I need an expalination.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    With non-overlapped clocks you can use all of the edges without violating set-up and hold-time restrictions. If the clocks overlap then the leading edge of the next clock precedes the trailing edge of the previous clock.
  3. andrea86
    Sep 30, 2010
    12
    I need an explanation why are clocks non overlapping?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps you can post up the circuit?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Older CPUs used to use them a lot, it was to keep data moving inside the CPU. Basically you make an oscillator, then add a simple phase shifter/Schmitt Trigger. Walla! Two separate clock signals that don't overlap. If you try to make two different oscillators this is almost impossible.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I question the 200 msec delay as stated. What is the master clock frequency and what devices are you using (by type number)?
  7. andrea86
    Sep 30, 2010
    12
    I need a good explanation.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  9. andrea86
    Sep 30, 2010
    12
    Thank you,bat that's not a question.I only need an explanation
    how does this circuits works,or why this circuit makes non-overlapping clocks?
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    The answer is simple, phase shift. You have two identical frequencies (truly identical) which are shifted by some angular amount (which is why the RC circuit is there on the earlier replies).
    You are making this complex, more so than it needs to be.
    The circuits you are showing are depending on propagation delay of the chips. Over complicated, and there won't be much difference between edges, just enough.
  11. Kit_Leong
    Dec 4, 2010
    5
    to andrea86,
    Hello,Im using the same circuit u mentioned above for a 2 phase non overlapping clock signal http://tams-www.informatik.uni-hambu...-clock-gen.htm ,Im using it as a clock signal for my modulator/demodulator as I am doing a chopper stabilized bandgap reference circuit.Did you manage to get a non overlapping signal?I cant seem to be able to get it,I'm using mentor graphics for my simulation,attached is a picture of my waveforms and circuit,do you know why it is not overlapping?i already followed this schematic but still not getting the expected results[​IMG]
    if u cant see the picture i attached,try looking here <snip>
  12. Kit_Leong
    Dec 4, 2010
    5
    The pictures I tried to attach in the previous message are here,thanks.
  13. eblc1388
    Nov 28, 2008
    1,542
    102
    It depends on understanding what limitations your simulation software has.
    Here is a simulation done the free LTSpice IV.
  14. Kit_Leong
    Dec 4, 2010
    5
    yea thats the same circuit you are using that i'm using as well,thats odd if a circuit can work on one software and not on another,currently I thought of something else but it seems too simplistic to work,though I did manage to get the expected results,what do you think of it?
    I tried to put a Vpulse signal to 1 output,and for the 2nd output,I added a slight delay to the Vpulse so its shifted just nicely to look like a non overlapping waveform.
    Is it ok to do this instead?but if it were that simple I dont think people will use more complicated circuits to get the job done now would they?Thanks.
  15. eblc1388
    Nov 28, 2008
    1,542
    102
    Anything that works for you works. :)
    Kit_Leong likes this.
