Have reinstalled my Windows.
Now the MPLAB 8.88 will not build the HEX file correct.
Have NOT changed anything in the source code.
It writes this when Building
As u can see, the config bit is just one, it needs one,
Have i installed something wrong or some setting ??
Rich (BB code):
Memory Summary:
Program space used 14DFh ( 5343) of 2000h words ( 65.2%)
Data space used BCh ( 188) of 200h bytes ( 36.7%)
EEPROM space None available
Configuration bits used 1h ( 1) of 2h words ( 50.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Free mode.
The MPLAB XC8 PRO compiler output for this code could be 2022 words smaller.
See http://microchip.com for more information.
