Non-sinusoidal periodic supply noise (rs232 caused)
Discussion in 'Embedded Systems and Microcontrollers' started by aeroguy, Jul 25, 2012.
  1. aeroguy
    Sep 16, 2009
    40
    I'm using a Sipex SP3232 chip in a 5V circuit.
    I discovered that as long as the sp3232 is powered, even when it's not actually connected to a serial line or being used actively, it creates a periodic disturbance in my supply voltage.
    The waveform is at a frequency of 130 kHz, and consists of a distinct bump that is 13mV in amplitude. It almost looks like a 25% duty cycle PWM signal, to help you visualize. This behavior seems to correspond to one of the internal operations of the 232 chip, as it cycles through 4 internal processes.
    The problem with this disturbance, is that it is causing troublesome noise for some instrumentation amplifiers sharing the same power source.
    Anyway, it isn't obvious to me how to filter this sort of thing, since it's not sinusoid in nature. I already have numerous bypass capacitors of the common values used all over in my circuit (0.1, 0.01, 0.22 uF, etc.)
    Has anyone here ever had to address this issue before? Any thoughts on filtering, etc?
    thanks,
    Eric
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    You could try to "isolate" the sp3232 from the rest of the ciruits using a 10 Ohms resistor in the Vcc line of the sp3232 and a 0.1 μF and a 1 μF capacitor from Vcc to ground on this sp3232.
    Bertus
  3. aeroguy
    Sep 16, 2009
    40
    Thanks, Bertus. I'll definitely give that a shot tonight.
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Another thing to try if you can do it is to run separate physical power lines (Vcc and GND) to the 232 chip and to the IA/analog stuff all the way back to the power supply. Then heavily decouple them there. The object is not to share the V/I surges from the 232 with any of the sensitive analog circuitry by sharing current paths.
  5. aeroguy
    Sep 16, 2009
    40
    Thank you, sir. I will try this as well.
    All of the feedback is greatly appreciated!
    Eric
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Serial 232 chips usually use a charge pump oscillator and some caps to generate the _/-12v voltages needed for RS232 serial.
    It should have a pretty good decoupling cap, I would go a few times larger than the charge pump caps, so maybe 47uF for its decoupling cap. A tantalum is good.
    And like Bertus said use a 10 ohm resistor before the cap, and a 0.1uF cap as well .
  7. aeroguy
    Sep 16, 2009
    40
    Bertus! Thanks, man.
    The solution was indeed a 1 uF cap, but I needed a 500 Ohm resistor to get the job done.
    Thanks again, you saved me much time and madness.
    Eric
  8. aeroguy
    Sep 16, 2009
    40
    Thank you. I may try this as well, because the larger (500 ohm) resistor I'm using does impact the rs232 transmission a bit. Will report back what happens with a larger capacitor.
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
