Non-repetitive peak forward current
Discussion in 'General Electronics Chat' started by tiptonian, Jun 30, 2010.
  1. tiptonian
    Jun 30, 2010
    Non-repetetive peak forward current for a diode is quoted on datasheets for a square pulse of particular current and time. How should you treat other waveshapes, such as a reverse sawtooth (fast rise, slow decay) such as you get through a blocking diode to charge a capacitor via a resistor from a source with a fast rise time?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    One option would be to use the equivalent value of
    It=\int ^{t}_{0}{i(t)dt}
    or maybe ???
    I^2t=\int ^{t}_{0}{i(t)^2dt}
    for a different waveform.
    The latter lends some weighting to the let-through energy concept such as one associates with the rating of semiconductor fuses.
  3. The Electrician
    Oct 9, 2007
    2,301
    339
    The most accurate method is to use the transient thermal impedance model for the diode. See:
    http://www.pwrx.com/pwrx/app/zth_underchip_nf.pdf
    http://www.fairchildsemi.com/an/AN/AN-7522.pdf
    and many other references found by searching for the phrase "transient thermal impedance".
    Most rectifier diode spec sheets I've looked at specify the non-repetitive surge with a half-sine waveform.
    See the attachments, which also discuss derating for low duty cycle.
  4. tiptonian
    Jun 30, 2010
    Thanks for the suggestions; unfortunately the device (BAS16L, NXP) does not have any transient thermal impedance data. The SPICE approach is interesting if I could find some values to plug into the circuit, perhaps relating to a mechanically similar part. I shall think on that.
  5. nomurphy
    Aug 8, 2005
    567
    12
    Note the term "non-repetitive".
    In other words, it is the one-time peak current. I would not try to rationalize it as area under the curve for some other waveform type, when used in a practical circuit, but stay well below the spec.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    For the single non-repetitive current pulse case, a search of the relevant literature might favor the equivalent "integral I squared t" approach rather than transient thermal impedance method.
