Non polar electromechanical relay?
Discussion in 'General Electronics Chat' started by Skeebopstop, Feb 17, 2010.
  1. Skeebopstop
    Thread Starter Active Member
    Jan 9, 2009
    358
    Dear all,
    I recently designed using a relay where the datasheet was unclear to me which polarity the coil had to be in to drive the switch out of its default position. So I put it to the test. An image is attached from the datasheet.
    When I applied voltage in either polarity to the coil, the relay would switch the contact over. I am a bit at odds with this. Obviously there is an explanation for this that extends beyond my assumption that this sort of relay was permanent magnet driven.
    James
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Most relays do not have a permanent magnet in them. They use a coil to induce a magnetic flux in a ferrous armature with a gap. The induced magnetic attaction causes the armature to move to close the gap. A spring pulls the gap open when the current is removed.
    e.g. think about an AC relay.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    When you do think about an AC relay, also think about the copper D ring at the top of the coil pole piece and why it is there.
  4. Bernard
    Aug 7, 2008
    4,240
    414
    There is also a latching relay that does use a magnet. It latches with one polarity & releases on polarity reversal.
