non-lvalue in assignment (c++)
Discussion in 'Programmer's Corner' started by sasha12, Oct 19, 2007.
  1. sasha12
    Oct 19, 2007
    Hi, i'm a little bit new in programming, and i had an error in this following dev-c++ code:
    (don't worry if you don't understand everything, it's in spanish)
    #include <iostream>
    #include <cstdio>
    #include <cstdlib>
    #include <strings.h>
    #include <string>
    using namespace std;
    class shop
    public:
    int size;
    string chooseTV;
    float tvPrice;
    int buyTV()
    shop *pSize;
    shop futureTV;
    string prod = "x x x x x";
    char* pTC;
    char* pTE;
    pTC = new char [prod.size()+1];
    strcpy (pTC, prod.c_str());
    cout << "Eliga una de estas 5 marcas que le ofrecemos: \n";
    for (int i = 0; i < 5; i++)
    cout << prod << endl;
    cin >> futureTV.chooseTV;
    pTE = new char [futureTV.chooseTV.size()+1];
    strcpy (pTE, futureTV.chooseTV.c_str());
    cout << "Ahora por favor inserte las pulgadas de su televisor\n";
    cin >> futureTV.size;
    pSize = &futureTV;
    futureTV.tvPrice = 100;
    for (int i = 0; i < 6; i++)
    if (i == 0 && strncmp(pTE, strtok(pTC, " "), 9))
    break;
    else if (strnicmp (NULL, strtok(pTC, " "), 9) = 0) //here is the error.
    break;
    futureTV.tvPrice += 100;
    if (i == 5)
    cout << "La marca " << pTE << " no esta habilitado en este mercado\n";
    cout << "Haga de vuelta los tramites\n";
    buyTV();
    if (pSize->size <= 5)
    futureTV.tvPrice += 50;
    else if (pSize->size <= 10 && pSize->size > 5)
    else if (pSize->size <= 20 && pSize->size > 10)
    futureTV.tvPrice += 300;
    else if (pSize->size <= 30 && pSize->size > 20)
    futureTV.tvPrice += 500;
    else if (pSize->size <= 35 && pSize->size > 30)
    futureTV.tvPrice += 2000;
    else if (pSize->size <= 45 && pSize->size > 35)
    futureTV.tvPrice += 5000;
    else if (pSize->size <= 55 && pSize->size > 45)
    futureTV.tvPrice += 10000;
    else
    futureTV.tvPrice += 20000;
    delete [] pTE;
    delete [] pTC;
    class television
    public:
    int channels [];
    string channelCable[];
    string channelName[20];
    int main (int argn,char* pArg[])
    can anybody tell me what happens here? thank you:cool:.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is your source code listing with coding style applied. The object is to make the code a bit more readable.
    hgmjr
  3. sax1johno
    Member
    Oct 20, 2007
    17
    Hey There,
    Could you please post the errors that the compiler is giving you (exactly)? That would be more helpful.
    L-value assignments are sometimes indicative of attempting to use invalid operations on data structures (ie: Attempting to assign an integer to a pointer).
    If you post the specific compiler problems, I can help you a little better.
