Non-linear voltage adder?
Discussion in 'The Projects Forum' started by relativity, Dec 12, 2006.
  1. relativity
    Dec 12, 2006
    First of all, I'm new to this sort of thing but I have a project in mind that I'd like to try to create and I need help.
    I have a non-linear sensor with a 0-5v output that I'm trying to combine with a second, identical sensor's output to measure a combined total. The sensors may have significantly different values at times, so I can't average their voltages. I need to add them using a lookup table.
    For example, the sensor's output voltage is the square root of the measured quantity (lbf for example). So a measurement of 4 lbs yields a sensor output of 2 volts. 9 lbs = 3 volts, 16 lbs = 4 volts, etc.
    So if sensor A reads 2 volts (4 lbs), and sensor B reads 3 volts (9 lbs), the combined voltage output would be 3.6 volts (13 lbs).
    Logic:
    1. Compare sensor A's voltage to the lookup table (2v = 4)
    2. Compare sensor B's voltage to the lookup table (3v = 9)
    3. Add the table values (4 + 9) and, using the table, determine the combined voltage (13 = 3.6v)
    The actual circuit is not a convenient equation, so it would need to interpolate between adjacent values (linear interpolation is fine).
    How would you recommend creating such an adder? If you can at least point me in the right direction, I'm willing to do the legwork. I'm hoping you can at least save me from going down the wrong path(s) and wasting time. Thanks!
    Rel.
  2. kubeek
    Sep 20, 2005
    4,688
    806
    what about using opamp logarithmical converter for each signal, amplify it by 2,
    then use exponential converter. This will make the signals powered by two.
    then you add them, and use the same method to make a square root if you want (use gain 0.5).
    hint: 2*log(x) = log(x^2)
  3. relativity
    Dec 12, 2006
    Thanks for the reply! It turns out the actual table isn't a convenient X^2, I just used that as an example. However I found a way to simplify this. I can represent this whole operation as a single equation as follows:
    Vout = 0.8054*(VA^3.2 + VB^3.2)^0.3125
    For example, let's say Sensor A is 2 volts (VA) and Sensor B is 3 volts (VB). Using the equation above my combined Vout = 2.61 volts.
    This is an approximation of the actual table, but it's accurate to within 10%. How do I create a circuit which replicates the equation above?
    To clarify, there are two input voltages (VA and VB) and one combined output voltage (VOUT) with a ground reference of course.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look up a data sheet for a four-quadrant multiplier ic. As long as you're dealing with constants, then it should be possible to crank out a function. The four-quadrant device will act as a mixer for your two sensor signals, and may also be able to tailor the response of each to fit the function.
  5. kubeek
    Sep 20, 2005
    4,688
    806
    And what about using A/D converter and a PIC to count the equation? It might be easier than creating this quite complex equation discretely.
  6. relativity
    Dec 12, 2006
    If I'm following correctly, you're suggesting a selection of these arranged in order to reproduce the equation?
    Analog Multipliers/Dividers
    AD538 looks like it will perform the exponential and scalar calculations, but I'm not sure about the addition.
    I like easy, this sounds interesting?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The addition can be done in an op amp inverter. The inputs each put current through resistors feeding the inverting input, which will add them together.
  8. kubeek
    Sep 20, 2005
    4,688
    806
    Yes it sounds easy, but you probably have to find someone who can do it. I never programmed a microcontroler, I just know that this is possible.
    BTW how fast are the changes of the signals?
  9. relativity
    Dec 12, 2006
    I'm trying to verify, but I think the sampling rate is about 200 Hz.
