?Papabravo said:You know -- a poem about death
An ode is a lyrical poemAnother typical example is the transistor, with its switching operation.
A doubly balanced diode mixer is another classic example. Two frequencies go in and four frequencies come out. The trigonometric identities to prove it are pretty rough going, but it can be done with high school math.Another typical example is the transistor, with its switching operation.
Die-ode... I get it. But I guess it's not a good pun if you have to think about it twice.An ode is a lyrical poem
http://en.wikipedia.org/wiki/Ode
A famous example of which in English is by Keats, Ode upon a Grecian Urn
http://englishhistory.net/keats/poetry/odeonagrecianurn.html
so a (die) (ode) is a poem about ...well you get the idea
The best way to understand this is to define what a linear load is, and then realize that everything else in "nonlinear".Hi,
I am doing an assignment on Harmonics and the textbooks and handouts I am using refer to non linea and linea loads. Please could someone explain what is meant by non-linea loads and an example please?
Thanks alot
ElecNerd
