non-inverting summing amp
Discussion in 'Homework Help' started by fran1942, Sep 3, 2010.
  1. fran1942
    Jul 26, 2010
    58
    Hello, my tutor has asked me to sketch a non-inverting summing amp with three inputs.
    I understand all the other common amp configurations, but I am unsure how to sketch this one.
    Can someone please show me a basic example with some figures so I can clearly see how the individual gains are calculated with three inputs ?
    Thanks kindly for any help.
    (I have searched the web, but most examples just have formulas rather than actual figures)
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you allowed to use two opamps? If so, then add an inverting unity gain opamp to the output of your inverting summing amplifier.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. fran1942
    Jul 26, 2010
    58
    thanks, great advice,
    Would this attached sketch work.
    I need gains of 4, 10 and 15.
    Thanks kindly
      File size:
      88.3 KB
      49
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Sorry that will not do the trick. You have used a non-inverting unity gain buffer. What you need is an inverting unity gain amplifier.
    hgmjr
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I didn't bother checking gains, you should be able to do that.
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    Thanks Bill. That is what I was suggesting.
    hgmjr
  8. fran1942
    Jul 26, 2010
    58
    thanks guys, I really appreciate your help.
  9. fran1942
    Jul 26, 2010
    58
    excuse my ignorance, but can I just ask why the two 2x 1K ohm resistors are in place ?
    Thanks kindly.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is a unity gain inverter circuit. Which is why converts the first inverting circuit into a non inverting circuit per your requirements.
    The exact resistors values aren't important, they need to be the same values for unity gain.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
