Non inverting op-amp Plz help
Discussion in 'Homework Help' started by need_help, Jan 28, 2010.
  1. need_help
    Sep 7, 2009
    23
    I need some help for figuring out the output voltage for:
    V1 = +0.1 V (DC)
    V2 = 0.1 V (p-p) sinusoid
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Are you able to work out the effective voltage at the op amp +ve input terminal? R1 & R2 values will have an important effect on this value.
    Assume the amp has infinite input resistance at either input terminal.
  3. need_help
    Sep 7, 2009
    23
    For the non-inverting op-amp:
    Vout= Vin (1+(R3/R4))
    How do I handle Vin (V1 and V2) ?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    V1 and V2 make a voltage divider that reduces the AC signal to the opamp and will reduce the DC if V2 has a DC voltage.
  5. t06afre
    May 11, 2009
    5,939
    1,222
