non-inverting buffer
Discussion in 'Homework Help' started by anhnha, Apr 30, 2014.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    I got stuck with an exercise about non-inverting buffer. Please help me with the question below.
    Thanks.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Imagine that the output is driving a fairly light load. The easiest way to do this is to put two resistors on the output with one tied to each rail.
    anhnha likes this.
  3. anhnha
    Apr 19, 2012
    776
    48
    Do you mean this?
    I still have no idea how to derive that. As Vin < VT, it seems that the PMOS is in ON while NMOS is in sub-threshold region.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    If the PFET is on, then what is it's Vgs (at a minimum)?
  5. anhnha
    Apr 19, 2012
    776
    48
    Vgs = - Vt (minimum)
    For PMOS to be on, Vsg ≧ |Vtp| = Vt
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    So what does that tell you about the output voltage?
  7. anhnha
    Apr 19, 2012
    776
    48
    For the pmos, vgs is still unknown.
    Vg = Vin < Vt
    Vs = Vout = unknown
    Vsg = Vs - Vg = Vout - Vin is unknown.
    So, how can I know if is is ON or OFF?
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    With Vin = 0V, you've indicated that the NMOS is off. So remove it from the circuit. Now also remove the bottom resistor. This leaves you with the PMOS and a pullup resistor. Can you figure out what Vout is? Again, assume that the resistor is sized such that it only lightly loads the transistor.
  9. anhnha
    Apr 19, 2012
    776
    48
    Id = k (Vsg - Vt)^2 = k (Vout - Vin - Vt)^2
    With Vin = 0V, Id = k (Vout - Vt)^2
    Vout = Vdd - Id*R1 = Vdd - k*R1 *(Vout - Vt)^2
    Solving for Vout, I get:
    Vout1 = Vt + (( -1 + sqrt(1 + 4k*R1*(Vdd - Vt)))/(2k*R1)
    Vout2= Vt + ((-1 - sqrt(1 + 4k*R1*(Vdd - Vt)))/(2k*R1)
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Come on!
    What is the lowest voltage that Vout can get to before the PFET turns off?
  11. anhnha
    Apr 19, 2012
    776
    48
    PMOS turns on:
    Vsg ≥ Vt
    or
    Vout - Vin ≥ Vt
    Vout ≥ Vin + Vt
    With Vin = 0V, Vout ≥ Vt.
  12. Jony130
    Feb 17, 2009
    3,991
    1,116
    Find Vout for this circuit.
      File size:
      5.7 KB
      18
    anhnha likes this.
  13. anhnha
    Apr 19, 2012
    776
    48
    I don't know why the two circuits are equivalent. However, for the circuit on the left, Vout = 0.7V with the assumption that Vbe is constant and equal to 0.7V.
    BTW, why can we replace the npn transistor by a resistor?
    Shouldn't the transistor be OFF? So, it is open circuited. As a result, there is no current flowing through the pnp transistor and the pnp is also OFF. That is my confusion.
  14. Jony130
    Feb 17, 2009
    3,991
    1,116
    Because we always have some small leaking current. And this resistor help as visualizes this current. So we the P-MOS we have Vout = Vin + Vgs and for Vin = 0V ---->Vout = Vgs. Because Id current is very small and this is why Vgs = Vp
    Vgs = (1 - \sqrt{\frac{Id}{K}}) * Vp so for Id = 0A Vgs = Vp.
    anhnha likes this.
  15. anhnha
    Apr 19, 2012
    776
    48
    I think this is sub-threshold operating region. I have been reading about it for some time but doesn't get a good grasp of it.
    For the input-output characteristic of the buffer, I think it is not completely exact.
    As Vin = 0, Vout = Vt as you said above.
    However, as 0< Vin<Vt, Vout = Vin + Vt not just Vt.
    Am I right?
  16. Jony130
    Feb 17, 2009
    3,991
    1,116
    That seems logical to me also. But maybe we're both wrong.
    anhnha likes this.
  17. WBahn
    Mar 31, 2012
    18,087
    4,917
    So plot Vout = Vin + Vt on the graph you originally posted.
  18. anhnha
    Apr 19, 2012
    776
    48
    Do you mean that Vout = Vin + Vt is right?
    In the solution, it seems to be Vout = Vt for all Vin from 0 to Vt.
  19. WBahn
    Mar 31, 2012
    18,087
    4,917
    But if Vout = Vt when Vin = Vt, then that means that the Vgs of the PFET is 0V, in which even a high resistance (such as an NFET with just a little bit of leakage) will pull the output node up toward the upper rail. This will continue until the Vgs of the PFET reaches about a threshold voltage at which time the PFET will turn on just enough to hold that voltage.
    What you will find instead of the diagram given in the answer, is that there will be a deadband in the middle that is about the width of the sum of the two threshold voltages. If you think about it, if the voltage is at half the supply voltage, then the system is basically symmetric (assuming balanced transistors) and there is no reason for the output voltage to be anything other than half the supply voltage. That situation won't change appreciably until the input voltage either moves upward by an NFET threshold voltage or downward by a PFET threshold voltage.
    anhnha likes this.
