non inverting buffer ic required
Discussion in 'The Projects Forum' started by rasheed_it, Aug 21, 2011.
  1. rasheed_it
    Mar 26, 2011
    12
    hi i need a non inverting buffer ic with output enable that works with a supply voltage of 12v. please suggest an ic other than 4503.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. rasheed_it
    Mar 26, 2011
    12
    its rarely available in market :(
  4. rasheed_it
    Mar 26, 2011
    12
    I again got stuck the other two ic are not available too. Please suggest any other.
    Or can anyone help me making the outputs of the ic 4050 of high impedences only when i receive a high signal? Please help am stuck on the last stage of designing....
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Where do you buy your components (which shop exactly)? Is this an online dealer?
    Can you buy your parts from digikey India or is this too expensive?
    If you post your circuit it may be possible to find a workaround for your problem, without using the buffer.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    RS components in the UK has 4503's made by a number of manufacturers. You can order them online and have them shipped to you.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Buy a microcontroller that has a sufficient number of I/O pins to do what you need to do, and then program it to do the function.
  8. praondevou
    Jul 9, 2011
    2,936
    489
    Well that seems to be a bigger modification, if done with discrete components.
    I found THIS list from someone living in Bangalore, see if it helps.
    You can also look through the IC's from alldatasheet.com. Put in "HEX NON-INVERTING 3-STATE BUFFER" in description search field, as you can see there are quite a few results, you will have to look through to find a suitable one with the right voltage ratings and equal or similar pinout.
    rasheed_it likes this.
  9. rasheed_it
    Mar 26, 2011
    12
    Thanks a lot... i have actually checked most of the distributors from the list. I will try the rest. Hope i find it. Thanks a ton
