Non-inverting amplifier
Discussion in 'The Projects Forum' started by ching fong kee, Jul 30, 2010.
  1. ching fong kee
    Jun 23, 2010
    42
    hi, guys
    For the UA741CN, i connect it as a non-inverting amplfier,
    and when there is no input voltage supply just only the Vcc and -Vcc
    and the output it show high voltage...
    should be in Zero or very small value right??
    And, now im supplying 0.45V to the input pin of amplifier and no matter how much i changing the value of resistor with R1 and R2
    the Output voltage is also same as the value that when there is no input voltage...
    is it got any reasons will cause it??
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Did you have a look at this page of the eBook:
    Divided feedback
    Can you post a schematic so we can give our comments?
    Bertus
  3. ching fong kee
    Jun 23, 2010
    42
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Assuming that you are using a dual power supply for your opamp, you will need to have a high valued resistor to ground on the positive input. Leaving the input open permits the input to float to an indeterminant voltage that is governed by the leakage current present at the input.
    hgmjr
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Are you using a double powersupply?
    What are the +Vcc and -Vcc values?
    Bertus
  6. ching fong kee
    Jun 23, 2010
    42
    yes, im using two power supply
    with +5V and -5V to op amp
    and i use +5V and -5V still cannot get the Vout i want
    i increase it to +15V and -15V but it show the output voltage is 0V
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    What is the nature of the input signal that you are applying?
    hgmjr
  8. ching fong kee
    Jun 23, 2010
    42
    i am using DC supply
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    So when you apply, for example, a 1 volt DC signal to the positive input of the non-inverting opamp, your output remains at zero volts?
    hgmjr
  10. ching fong kee
    Jun 23, 2010
    42
    ya, it is happended at zero volts when i'm varying the positive input from 0V to 5V when i'm using +15V and -15V to op amp
    but when i'm using +5V and -5V it shown 4.xxV
  11. hgmjr
    Jan 28, 2005
    9,030
    214
    What are the values of R1 and R2 in your circuit?
    hgmjr
  12. rajbex
    Nov 2, 2009
    22
  13. ching fong kee
    Jun 23, 2010
    42
    R1 i'm using 70K ohm
    R2 i'm using 10K ohm
    then the output voltage measured is 4.31V
  14. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you rechecked your wiring to make sure that you have the proper connections?
    hgmjr
  15. ching fong kee
    Jun 23, 2010
    42
    ya, i'm rechecked again and again..
  16. hgmjr
    Jan 28, 2005
    9,030
    214
    You may have a damaged opamp. Do you have another opamp you can try?
    hgmjr
  17. ching fong kee
    Jun 23, 2010
    42
    yes, i'm change with 3 op amps already
    shown same result..
  18. hgmjr
    Jan 28, 2005
    9,030
    214
    Either your opamp:
    1. is damaged.
    2. has one or more of its pins short to another pin.
    3. has an open connection.
    hgmjr
  19. ching fong kee
    Jun 23, 2010
    42
    then from datasheet, it Vcc supply is give as +22V and -22V
    then i need to follow it?will it spoil?
  20. hgmjr
    Jan 28, 2005
    9,030
    214
    There is no need to power the opamp with anything more that +5 and -5 volts until you have determined what is keeping it from working. Raising the supply voltage could damage the part if something is wired wrong.
    hgmjr
