Non-Inverting Amplifier Question
Discussion in 'Homework Help' started by jegues, Feb 23, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    First let,
    R_{N} = R_{N1}||...||R_{Nn}
    R_{P} = R_{P1}||...||R_{P0}
    I'm trying to find the effect the non-inverting terminal has on the output. I first ground the inverting terminal and call the equivalent resistance there RN.
    Now I know that,
    V_{oP} = (\frac{R_{f}}{R_{N}} + 1)V_{in}
    Now that all that's left to do is find "Vin".
    The current across Rp1 will be Vn1/Rp1 as follows for the current across Rpn, Vnn/Rpn.
    Therefore by KCL the current across Rp0 to ground is the sum of all these currents, i0 = i1+...+in
    So the voltage as seen by the non-inverting terminal is simply Rp0 * i0 or Rp0*[i1 +...+ in]
    or equivalently,
    V_{+} = R_{P0} * \left[ \frac{V_{p1}}{R_{P1}} + ... + \frac{V_{pn}}{R_{Pn}} \right]
    but I'm having trouble converting this to the following form,
    V_{oP} = (\frac{R_{f}}{R_{N}} + 1) \left[\frac{R_{P}*V_{p1}}{R_{P1}} + ... + \frac{R_{P}*V_{pn}}{R_{Pn}} \right]
    I feel fairly confident I've got the work done right I just can't see how to switch between the two forms.
    Any ideas?
    EDIT: I found my mistake with currents i1 up to in, I was able to obtain the correct form now.
