I am talking about the current into the inverting input.Then could you explain in more detail what you mean by "through the op amp's output" in this sentence:
"The only paths the 1uA current into the inverting input can flow is through the op amp's output or through the load R."
If I'm looking at the same circuit you are, I see 3 terminals on the triangle representing the opamp. If 1 μA flows into the + input, it would seem that it must exit through the only other 2 terminals, namely the - input or the output terminal, or it must exit through the unshown power supply.
In order for it to flow through the resistor R, it must first pass through the ammeter, mustn't it? Or, it would have to reach R via the - input.
I don't understand how it can flow through R without also exiting the opamp's output terminal.
