Non contact current sensor
Discussion in 'The Projects Forum' started by abadi, Feb 16, 2010.
  1. abadi
    Nov 8, 2009
    16
    hiii guys
    i really need a help in my FYP , and its about non contact current sensor which is " Rrogowski Coil "
    just to make it short
    i have already design the coil and also the amplifier
    the coil already work for high frequency ( 1 M ) and the result is 24mV, but my project is about low frequency between ( 1 f - 1k f )
    so, i design the amplifier
    which is non-invierter and my ( Rf = 100 K ohms , Ri = 1 K ohms )
    so, my Gain is ( G = 100 )
    when i pass 1M frequency through the coil and i connect the coil to my op-amp
    but i dont get any result
    could any 1 help me on that ?????????
    why there is no result even the Gain is 100
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Can you post the circuit?
    What opamp / amplifier do you use?
    Greetings,
    Bertus
  3. abadi
    Nov 8, 2009
    16
  4. abadi
    Nov 8, 2009
    16
    did you get it ????
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What values did you use for R1 and R2?
    If R1=101 Ohms and R2 = 10k Ohms, you will get a gain of approximately 100.
    Post the design details of your Rogowski coil.
  6. abadi
    Nov 8, 2009
    16
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
  8. abadi
    Nov 8, 2009
    16
    Thanx bro
    i will try to do it tomorrow and see how its gonna work
  9. t06afre
    May 11, 2009
    5,939
    1,222
  10. abadi
    Nov 8, 2009
    16
    so, what i have to do ????
    i have to increase it or decrease the gain ????
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You will need an opamp with a higher gain product ( > 100 MHz ).
    I have attached a list of high speed opamps (remove the .txt and load it into excell).
    Greetings,
    Bertus
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Yes you must a faster OPAMP. Why did you select the LT1014 in the first place? Also perhaps split up the gain stage. Instead of 1 stage with gain equal to 100 try two stages with gain equal to 10.
  13. jpanhalt
    Jan 18, 2008
    5,699
    909
    Did you read the article by Cappels here: http://www.cappels.org/dproj/aciprobe/ACCurrentProbe.html
    He describes what you need to do to get low frequencies.
    What do your calculations (see Cappels) show? Can you describe your coil to us in more detail? What actual frequencies have you tried?
    John
