I just made one. I used three triangle wave circuits at three different frequencies going into an adder circuit and comparitor. Quite random, as long as the frequencies are not multiples of each other.Hello, I have a need to make a led that flickers like a loose connection like in a horror film, I know I can program it with an ardunio but it seems like a waste of money to have an ardunio power just one light. Any ideas on how I can do this.
It was probably Philips that discovered it - but it was found that driving a LED with a melody chip was more realistic candle effect than any circuit they could devise.Hello, I have a need to make a led that flickers like a loose connection like in a horror film, I know I can program it with an ardunio but it seems like a waste of money to have an ardunio power just one light. Any ideas on how I can do this.
Schematic?
I was discussing this with an IP attorney.It was probably Philips that discovered it - but it was found that driving a LED with a melody chip was more realistic candle effect than any circuit they could devise.
Is there no need for a series resistor?Here is a circuit I developed a number of years ago. I put two blinking LED's in parallel, and in series with a yellow LED to make a flickering candle for a pumpkin. I found that the two blinking LED's needed black shrink tubing on them to prevent all the LED's from talking to each otherView attachment 94904
Thank you. So am I correct in assuming just the top of the led is out the heat shrink could you possibly post a pictureBlinking LED's generally do not require a series resistor as they are normally rated at a maximum voltage because of the internal flashing circuit. LED's in certain circumstances will also detect light. In my circuit I cut two small lengths of shrink tubing, placed each one on the LED's, then used a heat gun to shrink the tubing. Shrink tubing is a common thing with electronics. It is different forms of tubing that
when heated is shrinks in diameter. In my opinion the most common is one that shrinks to half it's diameter.
by Duane Benson
by Jeff Child
by Jeff Child
