Nominal line
Discussion in 'Homework Help' started by leftbehind5805, Mar 17, 2010.
  1. leftbehind5805
    Mar 12, 2010
    8
    For a school project we are working on building a karaoke machine. We have to build a circuit based off the specifications I have listed below. What I have a question on is what is the nominal line constraint mean. If someone could explain this to me in simple terms, so that i can understand what it means, and what it is going to tell me about the circuit I am going to have to build.
    Equalizer Filter Center Frequencies: 50 Hz, 200 Hz, 800 Hz, 3.2 kHz, 12.8 kHz
    Equalizer Filter Bandwidth (BW): 2 octaves
    Input Signal: nominal "line" level (-10 dBv)
    Output Signal: nominal "line" level (-10 dBv)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
