noisy amplifier
Discussion in 'Homework Help' started by Rubs, Jun 20, 2011.
  1. Rubs
    Jun 20, 2011
    16
    can anyone help me design a "noisy" feedback amplifier with amplifier gain of 100 and signal to noise ratio of 60dB
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use a 741 op amp with badly filtered supply rails.
    Is this an assignment?
  3. Rubs
    Jun 20, 2011
    16
    yea...could you please elaborate on that
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Most people simply use a low noise audio opamp when they need low noise, not a noisy 43 years old 741 opamp.
    Audio opamps have a signal to noise ratio of up to 120dB.
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
    Oddly enough, he indicated that he wants a noisy amplifier. School projects are getting quite weird :confused:
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Use long cables not sheiled for the signal and power supply leads. And do not twist them them together. Use an unregulated power supply.
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you can get your hands in one, you can also use a 301 OpAmp. It doesn't have internal compensation and is particularly noisy.
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    And make sure that your circuit is totally devoid of decoupling components. :rolleyes:
  9. Rubs
    Jun 20, 2011
    16
    i simulated this circuit in LTSPICE but the results arent right...could anyone tell me whats wrong with this design and suggest a possible solution
    • SNR.doc
      File size:
      68.5 KB
      18
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Could you say what results were not right?
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Another though, you could deliberately introduce noise into the front end of the schematic. Bias up a zener diode with 10ma and have it feed in somewhere, for example. It is an old trick used to generate white noise.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    The polarity of V2 is backwards because it is supposed to be a negative supply. You have its negative terminal connected to ground so it is actually a positive supply.
    Why do you take the input signal and attenuate it down to almost nothing, then amplify it a lot?
    your negative feedback around both opaps looks odd and might cause oscillation.
  13. Rubs
    Jun 20, 2011
    16
    the frequency response doesnot give a gain of 40dB and the transient analysis gives out an output voltage of 700uV :-/ so clearly the design is not right...plz tell me what changes should i make
  14. Rubs
    Jun 20, 2011
    16
    i have given V2 a value of -15V i dnt think it would make much of a difference... and plz could you tell me explicitly wat changes i should make
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    I don't know why:
    1) You have an attenuator at the input of the first opamp.
    2) You have two opamps when the second opamp by itself will work.
    3) You feed the output of the second opamp back to the input of the first opamp as some kind of feedback.
  16. CDRIVE
    Jul 1, 2008
    2,223
    99
    Yes, great idea. Something similar to this was/is used by hams to make a noise bridge used for measuring 50Ω Z.
