Noise
Discussion in 'Homework Help' started by loity, Jun 4, 2004.
  1. loity
    Jun 1, 2004
    Please can someone give me some values of various noises in semiconductors in decibels. The type of noise in question is shot, partition, thermal agitation, flicker and also some reference to crosstalk and interference, also the effects of noise on circuits.
    Loity
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    am not going to give you the full details of your assignment but rather just give you a birds eye view of what you are asking.
    thermal noise is cause by thermal agitation of electrons in a device
    and can be computed by using Nyquist relation formula;
    V^2R = 4K x T x R x f
    V^2R = mean square of noise voltage
    K = Boltzmann constant ( 1.38E-23
    T = Kelvin temp.
    R = resistance in ohms
    f = noise bandwidth in Hertz
    shot noise or white noise is cause by changes in molecular energy level while the device conducts
    flicker noise is a low frequency effect, the lower the freq. the higher the noise. ( I/f )
    dBv refers to decibles relative to 1vrms
    dBu refers to decibles relative to 775mv
    0dBv = +2.2dBu
    interference is usualy\ly cause by RF signals, motor hum, static and many more.
    op-amp noise figure is usually expressed in ( nV / sq. rt. of frequency)
    doing research will give you a cleare picture :ph34r:
    check this site:oscillators
