Noise simulation in ltspice
Janani_Rajkiran
Joined Nov 1, 2016
46
Can anyone tell me about Noise simulation in LTSpice?
How Can I interpret that data?
what is the input noise level? in the output is the noise filtered out?
is there any other way by which i can simulate input noise and check if this noise is filtered in the output side?
Bordodynov
Joined May 20, 2015
3,181
Just the opposite! The larger the value the greater the noise resistor.
Green color -100 Ohm
Blue - 1kOhm
Red 10k
I took a simple electronic circuit and did the calculations. For one, I thought (with the command measure) integrated noise (input and output)
