I'm designing high precision pressure sensor signal conditioner.
And I would like to reduce noise.
Although many issue about the attached schematic exist, initially noise at between TP7/TP8 and 24PC sensor.
<Test 1>
When 3Pin(GND), 1Pin(+10V) is established, then meaure at TP7, TP8 position with 1.5M Shield Cable connected with J3
Peak to Peak Value
TP11(+10V) : 50mV
TP13 : 100mV FIG. 3_13
TP15, 16 : 100mV FIG. 3_15_1
TP15, 16 (Opened/Not Connected) :
65mV Signal Shape is same as FIG. 3_15_1
TP7,TP8 Peak to Peak : 80mV FIG_3_7, F_3_8
TP9,TP10 (Opened/Not Connected) : 300mV Signal Shape is same as FIG. 3_7
<Test 2>
When 3Pin(GND), 1Pin(+10V) is established, then meaure at 4Pin, 2Pin(Signal) without connection to J3(DIN Connector)
1Pin(+10V) Peak to Peak : 40mV
4Pin , 2Pin Peak to Peak : 30mV(Signal Noise size is reduced)
I found initial power supply ripple 50mV to signal 80mV ripple.
But Not connected signal ripple is smaller than power ripple.
Please give me help about how do I reduce this noise.
<Test 1>
Peak to Peak Value
TP11(+10V) : 50mV
<Test 2>
