noise on 0-5v signal line - need filter
Discussion in 'General Electronics Chat' started by elRey, Sep 22, 2009.
  1. elRey
    Thread Starter Active Member
    Feb 23, 2009
    65
    Hello, I'm trying to use a 0-5v signal from a car's sensor into a comparator. However, there's noise on the signal feed. I've acttached pictures of the noise in question. Multi-meter reads 1.89v. I need ~1.89v into the comparator (which varies as sensor works). The sensor is a Manifold Absolute Pressure sensor. The measurements below are at atm.
    The issue I'm having is as the signal gets close to the Ref V on the comparator, is falsely triggers the comparator on/off a wide range around ref V.
    I quickly tried a 0.1uF cap on signal line to gnd, and then a resistor in series with signal. No change.
    Main Time/Div = .2
    Vol / Div = .2
    Thanks,
    Rey
    Noise:
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Give this a try. See the attached; I just threw it together without spending time calculating things.
    The input is just a 2.5kHz 400mV square wave.
    R3 & C3 are just a simple 1-stage RC filter. Note the penalty paid for the simplicity in the cyan trace below; slow to respond and more noise.
    The yellow trace shows how much noise has been removed by the first stage of a 2-stage filter. The noise on C2 is very low in comparison to the other waveforms, and the response time is much better than the single stage filter.
    You can decrease the noise on C2 by increasing R1 and R2, but you will get slower response time.
    Or, you could simply add another stage.
    Noise in automotive environments is brutal.
  3. elRey
    Feb 23, 2009
    65
    I greatly appreciate you help Sgt. Going for a drive now to test your changes.
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    You might want to really increase the time constant of the filter. Manifold pressure will pulsate badly as the intake valves open/close and it requires quite a LOT of filtering to get an average pressure anyway.
    On a 4 cyl engine there will be 2 intake valve openings per rev, so at idle (say 1500 RPM) there will be bad pulsing at 1500 *2 valves /60 RPM = 50Hz. You probably want to set that filter pole at 5Hz or even slower and/or multistage filter.
  5. elRey
    Feb 23, 2009
    65
    the low-pass filter worked great. I ended up using 3.7K for both resistors. I could have gone smaller.
