I am using SMPS in my design to reduce temperature raising rate. The drawback is that noise generated is quite high, about 10%. So, I am finding a way to reduce the noise. May anyone suggest a way to reduce the noise? Some information is that my SMPS is at 100kHZ. Can I assume that the noise is at 100kHZ? I try using bandstop filter at 100kHZ. But it does not work. Please help me on this. Thank you.
