Noise in CRO
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Jan 29, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I am using CRO to measure area under grap plotted by DAC output from MCU.
    Problem is when I put probe on MCU output pin, there is random noise in signal i.e signal is not smooth.
    That why I cannot read exact area under curve from MCU.
    Earlier I thought noise could be from MCU pin. But I put the probe on GND pin of MCU, same random noise appears on it also.
    CRO ground pin is connected to ground pin of MCU.
  2. crutschow
    Mar 14, 2008
    13,502
    3,376
    What is the nature, frequency, and amplitude of the noise?
    Can you post a picture of it (including the CRO vertical sensitivity and sweep speed)?
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
  4. RichardO
    May 4, 2013
    1,341
    429
  5. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Shortening the gnd lead wire very close to CRO probe
