Noise from S/PDIF
Discussion in 'Computing and Networks' started by spinnaker, Feb 12, 2014.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,074
    1,176
    I have a XBMC setup with a PC, TV and audio amp. I get the sound via HDMI.
    I can't get it from the audio port direct because I have a spiller to feed HDMI to the upstairs TV. If I used the audio port, I would have no sound for upstairs TV.
    The downstairs TV has S/PDIF output. The audio amp is an older amp with no S/PDIF input. I purchased a S?PDIF to analog audio convertor.I have the output plugged into my DAD input of my amp. I also tried the aux and tape inputs on the amp.
    If I switch to TV or HDMI with Windows Media Center, I get a motor boating sound with very low audio.
    Media played on XBMC, plays fine. XBMC does use their own audio drivers.
    Any idea what would make this sound from TV and WMC?
  2. spinnaker
    Oct 29, 2009
    5,074
    1,176
    I need to post about problems on this form more often. I went to investigate the issue to see if I can provide more information. Unplugged and plugged things back together just like I did a couple of times before and the noise is gone!
    This is the 2-3 strange issue that went away after posting. :)
