I have been fiddling around with the 556 timer. As you know, a 556 timer simply incorporates two 555 timers in one chip.
Timer #1 generates a 180HZ square wave (I believe its called "astable"!) and timer #2 generates a 38 KHZ square wave. The ouputs of timer #1 and #2 connect to some other circuits. But there's one problem. When I connect the outputs of these timers to the rest of my circuit, my LCD screen flickers.
I am not an electronic engineer or anything (I only have college) and therefore, all I tried to do to resolve this is to try to put an integrator (a Resistor using a 5K pot, with a parallel cap (0.01)) and I have tried to vary the resistor and I see that the wave attenuates. But still, the flickering persists. The only time that the flickering stops is when I disconnect the timer #1, 180HZ output signal from the rest of my circuit.
What can one do to get rid of flikering caused by the output of the 555 or 556 timer chips.
I did try to put 0.01, 0.001, 0.1 and 4.7 mico farad caps in parrallel with my DC power supply and no luck.
Any suggestions?
With regards
Bob
Any suggestions?
With regards
Bob
