Noise Filter-MATLAB SIMULINK
Discussion in 'Programmer's Corner' started by whycanot, Jun 13, 2012.
  1. whycanot
    May 22, 2011
    54
    how to filter out all the noise from FTNoise.wav with using MATLAB?
    What is the settings needed in Digital Filter Design block?
    FTNoise.wav can be downloaded from here:
    http://www.mediafire.com/?sqjjr7qcai7vc4j
    click on the "Download (8.83MB)"
  2. whycanot
    May 22, 2011
    54
    anyone please help ?
  3. whycanot
    May 22, 2011
    54
    anybody help ? i tried this setting... but there's still noise ~
  4. whycanot
    May 22, 2011
    54
    100 ++ views , but no seniors help me T_T
  5. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    I can not download the file.
    I get the following message: You should Sign Up or Login to download this file
    I do NOT want to join the site, just to download a file.
    Bertus
  6. whycanot
    May 22, 2011
    54
  7. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    I did have a look at the file and found the following info.
    When you look at the last 5 seconds, you will see that all noise is above 8500 Hz.
    When you look somewhere in the middle of the file the noise is also visible above this 8500 Hz.
    You could try to make a filter that will remove the frequecnies above 8500 Hz.
    I do not have any experience with matlab, so yopu will have to look into it yourself.
    Bertus
  8. whycanot
    May 22, 2011
    54
    i need to use bandpass, bandstop, lowpass or high pass filter ?
  9. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    When you apply a lowpass filter the high pitch noise will be reduced.
    See the spectrum for the effect.
    Bertus
    PS all spectra are made with audacity an open source audio manipulating program
