Hello
I am trying to find the NOISE BANDWIDTH of second order filter.
I have a transfer function of a second order filter: 1/(as+1)(bs+1) which is obviously a cascade of two low pass filters with TF 1/(as+1) and 1/(bs+1).
To find the noise bandwidth, I need the area under the curve of the second order filter, which is equal to the filtered noise rms value given white noise input. I could get this by integrating the second order transfer function squared, but that is a giant pain to integrate and is very long.
I wonder if there is a simpler linear solution to this problem since the rms values/areas under the curves or bandwidths of the first order filters are relatively simple to find. Since this is not noise summation, but rather cascading filters, is there a way to find the solution by combining solutions of the first order filters?
ie mathematically, we have two functions of frequency. I can easily get the areas under each of the curves. I want the area under the curve obtained by multiplying the two individual functions. Can I get that area from the area of the individual curves?
Thank you very much.
