Noise analysis (flicker noise) of pico Ammeter readings
Discussion in 'General Electronics Chat' started by vikatmev, Aug 21, 2014.
  1. vikatmev
    Aug 21, 2014
    M given project to do noise analysis of pico ammeter ADC output. here the input is 1pA DC signal. for which i have nearly 100000 output samples. sampling rate is 3.5Kps. these readings have error percentage nearly 0.178%. So i need to do its noise analysis like i have to detect which types of noises it contain? separation of those noises and actual signal and their plots. frequency ranges of the noises etc. Initially i need to do this in matlab later in VHDL. i dont understand how to proceed. how to do noise analysis? means which parameters we should analyse and how??
  2. ronv
    Nov 12, 2008
    3,398
    1,455
    Spectrum analyzer?
    The bigger question might be what to do about it. How do you develop the voltage you are measuring?
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    at those levels, 1PA, every componant will contribute ssignificant noise, how do you intend to filter out the noise from the measurement process itsself?
