node voltage
Discussion in 'General Electronics Chat' started by Manasakrishna, Sep 17, 2010.
  1. Manasakrishna
    Sep 7, 2010
    7
    Voltage implies potential difference & for a difference to exist there must be two different points.Node voltage does not make any sense to me as it represent voltage at a point.So what does it actually mean.
    :).......Thank you
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It's normally understood as the potential difference between that node and the circuit common or reference node.
    Manasakrishna likes this.
  3. Manasakrishna
    Sep 7, 2010
    7
    Can you please elaborate this or refer sites which would put some light on this topic.Thank you.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Why not try Google or something similar - the web should be your best resource in this matter. Start with the search term "Node Voltage" and see where that leads you.
    The work you do yourself tends to be the most rewarding rather than relying on others to do it for you.
