Node Voltage Method
Discussion in 'Homework Help' started by solaris19, Oct 24, 2015.
  1. solaris19
    Oct 24, 2015
    Hi, I have this example. I'd like to use the Cramer's rule so I tried to construct the conductance matrix. But I'm not sure I'm doing it right. I need to determine V2, V3 and currents through all resistors. Thank you for your help!
    [G1+G2+G5+G7 -G5 0] [V10] [Iz1-Iz2]
    [-G5 G3+G5+G6 -G6] [V20] = [0]
    [0 -G6 G4+G6+G7] [V30] [Iz2]
  2. solaris19
    Oct 24, 2015
    I figured it out myself! You can delete this thread. Thank you!
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Show us your results so we can see if they are correct.
    Bertus
  4. solaris19
    Oct 24, 2015
    Hello, I made a mistake in the conductance matrix (the zeros should be -G7...I hope). I tried to use the mesh current method on the same circuit and the results seem to be correct now.
