node voltage analysis
Discussion in 'Homework Help' started by Hawkeye87, Oct 16, 2008.
  1. Hawkeye87
    Thread Starter Active Member
    Oct 7, 2008
    52
    ok, i'm stuck on this problem that's due tomorrow morning. I've worked it out and i get stuck right near the end. if anyone could help me i greatly appreciate it. The question says to find the voltage at node A.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It looks like all that you have left is to take your final equation and set it equal to zero and solve for Va.
    hgmjr
  3. Hawkeye87
    Oct 7, 2008
    52
    i've tried that. i factored out a Va and i solve for it and i get a really huge number.
  4. Hawkeye87
    Oct 7, 2008
    52
    i don't know where to go from there
  5. Hawkeye87
    Oct 7, 2008
    52
    well i free handed it and i got something like 1.73 V did anyone get the same thing?
  6. alwayslearning
    Member
    Feb 27, 2008
    22
  7. Hawkeye87
    Oct 7, 2008
    52
    does it matter what side the voltage is on? like on mine it was (30-Va)/82, for example.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    If you post the steps that you went through to obtain the answer you provided, then we can determine where you went off the rail.
    The answer I obtained was 28.308116V.
    hgmjr
  9. alwayslearning
    Member
    Feb 27, 2008
    22
    Hawkeye87:
    I apparently need to learn the nodal method myself! I saw the answer hgmjr provided; then reworked my solution using mesh analysis (see attachment). I ended up with the same answer as hgmjr:
    Va=28.307 volts
  10. Hawkeye87
    Oct 7, 2008
    52
    i have an exam one week from today and i have a practice exam that's due wednesday. If i upload it on here could someone guide me through it if i get stuck?
  11. hgmjr
    Jan 28, 2005
    9,030
    214
    Go ahead and post your problems here in the homework section.
    I would strongly encourage you to take a stab at the problems yourself and post what you have done.
    If you get us to solve the problems for you without any effort on your part, then we are simply ushering you toward failure. We don't want that and you certainly don't want that.
    Working practice problems is the only way to internalize the process. I would not stop with the practice problems. You can find many worked problems on the Internet. I would search for problems that have been solved and work toward understanding how they were done.
    hgmjr
  12. Hawkeye87
    Oct 7, 2008
    52
    would you happen to know of a place that i can find already worked problems that show the steps on how they got the answer?
  13. hgmjr
    Jan 28, 2005
    9,030
    214
    What type of problems do you need the most exercise on? (e.g. nodal analysis, mesh analysis, kirchhoff's voltage law, kirchhoff's current law, Millman's Theorem, Superposition)
    hgmjr
  14. Hawkeye87
    Oct 7, 2008
    52
    the exam will be covering Superpostion, Thevenins, Branch, Mesh, and Nodal Methods, and that's pretty much it
  15. hgmjr
    Jan 28, 2005
    9,030
    214
  16. Hawkeye87
    Oct 7, 2008
    52
    i can't really do much with reading text like that. i'm more of a visual learner and need to see examples myself and see how they worked through the problem and everything.
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    Go ahead and post your problems with any work you have been able to do thus far.
    Then we can see where that takes us.
    hgmjr
  18. Hawkeye87
    Oct 7, 2008
    52
    alrighty. sure will. give me a day or so to work on them an i'll edit this thread with the problems. there are only 4 problems.
  19. hgmjr
    Jan 28, 2005
    9,030
    214
    We anxiously await the opportunity to assist you with your learning efforts.
    hgmjr
  20. Hawkeye87
    Oct 7, 2008
    52
    thank you kindly. i'll be working on them tonight and through tomorrow then copy them in here and see if i get the right answers.
