Node analysis
Discussion in 'Homework Help' started by kidi3, Oct 16, 2012.
  1. kidi3
    Oct 16, 2012
    I currently trying to train my skills in analyzing a Electric circuit using the node analysis and mesh method.
    But the answers I get isn't the same as the one giving.
    http://personal.georgiasouthern.edu...43-lec/exercises-quiz3-mesh-nodal-w-ans.pdf
    I tried calculating Exercise 1 and 5 using Node analysis.
    these are my calculations for exercise 1
    http://snag.gy/Rfcp7.jpg
    And these are my calculations for excersice 5
    Har også lige prøvet opgave 5
    For V1 = 12v
    V2 = -2V
    I1 =6+(-3) = 3A
    V1 = 12V
    I2 = -1A
    -1 * 2 = -2V...
    And here is another one http://snag.gy/Dnuqf.jpg
    http://snag.gy/Rm2fs.jpg
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    You have here two unknown nodal voltages Vo and where we have 1Ω resistor
    Are you sure that this is a solution for exercise 5
    For node V1
    3A + V1/4Ω = 6A + (V2-V1)/1Ω
    And for V2
    5A = V2/2Ω + 6A + (V2-V1)/1Ω
    And solution
    V1 = 4V l V2 = 2V
    http://www.wolframalpha.com/input/?i=3+%2B+V1%2F4+%3D+6+%2B+%28V2-V1%29%2F1%2C+5+%3D+V2%2F2+%2B+6+%2B+%28V2-V1%29%2F1+
    You made a error in calculations X = - 12/11
    http://www.wolframalpha.com/input/?i=(12+-+X)/6+++(0+-+X)/4+-+(X+-+(-6))/2+==+0
  3. kidi3
    Oct 16, 2012
    About exercise 1.
    I see there is 2 resistors for the voltage source at 40V.
    Are those 2 in series or parallel.
    The equation I wrote gave me V_0 to become 25,0714V. But thats incorrect?..
    So should i change the resistors in parallel?
    About Exercise 5
    I didn't know how i should use the node equation here, because i seemed to be simple.
    I shoudn't have thought so..
    But using my knowlegde i get these equations.
    Are they correctly written?
    http://snag.gy/LWdjY.jpg
    And about the last one..
    Yeah I see my mistake.. - to +..
    Thanks for your reply.. I hope you help me with my other questions.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    You can not do that because you have a 5A current source
    So we need to nodal equations for two unknown voltages V1 and Vo.
    No, you forget about current sources.
    For V1 node we can write
    I1 + I2 = I3 + I4
    So we can write
    3A + V1/4Ω = (V2-V1)/1Ω + 6A
      File size:
      12.2 KB
      49
      File size:
      12.3 KB
      45
  5. kidi3
    Oct 16, 2012
    Ok.. I think i understand it now..
    what about..
    is it the direction of I0?
  6. kidi3
    Oct 16, 2012
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hmm, This current source has 1mA or 1A current ??
    First I assume that all current flow into the Va node.
    And all current which entering the node are positive ( give them "+").
    So I write
    1mA + (-Va)/R3 + (Vo - Va)/R2 = 0
    1mA - Va/510Ω + (0.5V - Va)/330Ω = 0
    And the solution
    Va = 503.929mV
    As for your equations, you made slight error.
    (0.5 - V)/330 - (-V)/510 - 1 = 0
    You also assume that all current entering into a Va node.
    but you assume that all entering currant are negative.
    So the correct nodal equations look like this:
    -(0.5 - V)/330 - (-V)/510 - 1 = 0
    -(0.5 - V)/330 +(V)/510 - 1 = 0
    Va = 200.661V
    Next time you should use this convention:
    Assume that all current flow out from the node and give them "+" if they flow out from the node.
    So we can write
    Va/R3 + (Va - Vo)/R2 + (-1A) = 0
    Va/510 + (Va - 0.5)/330 -1A = 0
    and solution
    Va = 200.661V
      File size:
      5.3 KB
      39
