node analysis
Discussion in 'Homework Help' started by yiannistamv, Sep 24, 2014.
  1. yiannistamv
    Jul 23, 2014
    35
    please see attached pdfs
    • 1.pdf
      File size:
      313 KB
      43
    • 2.pdf
      File size:
      323.8 KB
      32
  2. mjakov
    Feb 13, 2014
    20
    5
    Hi!
    The branch current method could be used for Figure P2.28. This method is similar to nodal analysis. Let the node between the 0.8V voltage source and the dependent current source be called C and let the lowermost node in the picture be the reference node.
    Kirchoff's Current Low at C:
     i_\beta + 29 i_\beta = 30 i_{\beta}
    Branch Current Equations
    From node C to ref. node:
     \frac{v_c}{200} = 30 i_\beta
    Left branch:
     \frac{15.2 - (v_c - 0.8)}{10^4} = i_\beta
    It follows:
     i_\beta = 10^{-3} A
     v_c = 6 V
    yiannistamv likes this.
  3. yiannistamv
    Jul 23, 2014
    35
    thank you very much but can yu tell what is wrong with the equation i come with?
  4. mjakov
    Feb 13, 2014
    20
    5
    Hi!
    Is your equation in Fig. 2.28 obtained by the KVL of the outer circuit loop? If so then, have you considered the voltage drop at v_y and the 25 V source. Where have you got the value 15 in your equation from?
  5. yiannistamv
    Jul 23, 2014
    35
    thank you mjakov the 15 value is the 25 by mistake and you are right thank you
