Node analysis of RLC circuit using Laplace transform
Discussion in 'Homework Help' started by abhaymv, Aug 7, 2011.
  1. abhaymv
    Thread Starter Active Member
    Aug 6, 2011
    105
    Hello everyone,
    I have been having some problems with the circuit attached.We were asked to find V1 and V2 at the nodes.The circuit opens at t=0 and disconnects from the Voltage source.The source voltage is 1 Volt.The initial values are:
    Vc(0+)=1 V
    iL(0+)=1 A
    L=0.5 H
    C=1 F
    G=1 mho(Or Resistance,R = 1 ohm)
    I have to solve this by using laplace transforms, mathematically.I think I found part of the solution,but I am unsure.
    Equation 1:
    (1/L)*∫(V1(t)-V2(t))dt+C(d/dt)(V1(t))=0
    Corresponding Laplace equation:
    (2+s)*V1(s)-2*V2(s)=s-1-----------------(1)
    Equation 2:
    (1/L)*∫(V2(t)-V1(t))dt+V2*G=0
    (Conductance,G is taklen)
    Laplace:
    -2*V1(s)+(2+s)*V2(s)=-1----------------(2)
    Solving (1) and (2):
    2*(1)+(2)*(2+s):
    we get:
    V2(s)=(s-4)/(s^2+4*s)
    or V2(t)=-1+2*exp(-4t)
    Is my answer correct?:confused:
    Similarly,I got:
    V1(s)=(s^2+s-2)/(s^2+4s)
    This doesn't seem right..does it?Have I gone wrong somewhere?
    Thank you in advance for your help :D
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    I have the same node equations, but when I ran through the Lapalace transforms I arrived at the following:
    Equation 1:
    (2 + s^2)V1(s) - 2V2(s) = s - 1
    Equation 2:
    -2V1(s) + (2 + s)V2(s) = 1
    Assuming I didn't err somewhere,
    In eq. 1 I think you forgot to multiply the sV1(s) term by s when clearing the fractions after the transform.
    In eq. 2 it looks like you reversed the direction of the initial current through the inductor when performing the integral transform.
    Mike
    abhaymv likes this.
  3. abhaymv
    Aug 6, 2011
    105
    Thank you!that explains it.got to work more on these type of problems.
