nodal voltage analysis method
Discussion in 'Electronics Resources' started by sadaf, Aug 13, 2010.
  1. sadaf
    Aug 4, 2010
    25
    Please solve this problem by using nodal voltage analysis method, i am so confused in it,
    in this problem we have to find out the current I3.
    Ok, i am attaching a file here plz solve this for me thanx.....
    View attachment 5555555555.doc
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Is this a homework problem?
    hgmjr
  3. sadaf
    Aug 4, 2010
    25
    No it is not,ACTUALLY I WAS TRYING TO SOLVE THIS BUT IT IS very very difficult.......
    I shall be thank full to you if you solve this for me.....
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    If you don't have to use nodal analysis you can use some simplifying reductions to obtain the current in R3 (was that I3?). I haven't double checked my attached method - but the process would be a reasonable one.
  5. sadaf
    Aug 4, 2010
    25
    The image which u have attached, is not opening.........?
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    It opens just fine for me.
    hgmjr
  7. Curleeee
    Aug 12, 2010
    7
    I have same (correct!) answer as T N K.
    Sadaf: Could I recommend that you try to get a LOT of practice solving networks. This process is fundamental to many branches of Electrical/Electronics Engineering.
  8. Ghar
    Mar 8, 2010
    655
    72
    I'm a huge advocate of Thevenin style methods (source transformations, equivalent resistances, etc.) like what t_n_k did over loop and nodal analysis.
    Algebra is just lame I think, I avoid it wherever I can.
    I do agree practice with it is important though, if only because sometimes you are stuck with nodal analysis.
  9. Curleeee
    Aug 12, 2010
    7
    Ghar - Use every trick (sorry, technique) in the book to get the correct answer to a problem with the least effort. Then verify the answer.
    Algebra can sometimes be useful if a formula type solution is needed. Again, there are ways of verifying formula solutions.
  10. sadaf
    Aug 4, 2010
    25
    Ok corleeee,but can you tell me if we take the directions of all currents at a node in such a way that they are leaving the node.......
    Then in that condition will my answer is true if i take the direction of currents in such a way........?
  11. sadaf
    Aug 4, 2010
    25
    Still not opening.............
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    Have attached the two solutions as they were posted - but in pdf format. You need to download them and open with a pdf viewer such as Adobe Acrobat. Hope this helps.
    sadaf likes this.
  13. Heavydoody
    Jul 31, 2009
    140
    11
    Here is the nodal solution if you are still interested.
    sadaf likes this.
