Nodal Analysis?
Discussion in 'Homework Help' started by tquiva, Dec 22, 2010.
  1. tquiva
    Oct 19, 2010
    176
    For part a, would I just do this through nodal analysis at Vn?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Note that the source to the right is a dependent voltage-to-voltage source. So be careful how you do the analysis. Using Nodal analysis is OK.
  3. tquiva
    Oct 19, 2010
    176
    is the branch containing the 8V a supernode?
    I'm not so sure how to solve it with that 2 ohm resistor next to it
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Doesn't look like a super-node.
    An careful look at the circuit would tell you that Vo=VN/2. By virtue of the voltage divider formed by the two 1Ω resistors. So 2Vo=VN. If there is no difference between VN and the dependent source output (=VN) what would the current in the dependent source branch be?
    From there you will be able to deduce the remaining circuit conditions.
