Nodal analysis
Discussion in 'Homework Help' started by nyasha, Apr 14, 2009.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    Guys l have a final exam tomorrow and l desperately like to like to know how does the the voltage at node D become :
    Vd=-(Vc-Va)=Va-Vc
  2. The Electrician
    Oct 9, 2007
    2,300
    335
    Calculate ix = (VC-VA)/2. You see why this is, I hope. Ask if you don't.
    Then the dependent source feeding VD has a voltage VD =-2*ix. Substituting what we calculated for ix above, we have VD = -2*ix = -2*(VC-VA)/2 = VA-VC.
  3. The Electrician
    Oct 9, 2007
    2,300
    335
    The OP hasn't anything more to say, but I know that tnk and HGMJR want to try out their skills by solving this one.
    What is the voltage at each node?
    And, what is the impedance (incremental resistance) to ground at each node?
    I've given it some effort, and I will say that attention to detail is necessary!
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The sweat is pouring from my brow! Calculator is smoking!
    I pity the poor student ["nyasha"] if that's a typical exam question.
    OK "electrician" I just did the voltages - you're a hard man asking for the impedances!
    I hope ... :(
    VA = 3.243 V
    VB = 5.270 V
    VC = 0.811 V
    VD = 2.432 V
    VE = VX = 0.270 V
    And I didn't use matrices to solve the simultaneous equations :)
    BTW - what are the impedances?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    PS - Is there an exploding head "smiley" face?
  6. The Electrician
    Oct 9, 2007
    2,300
    335
    "I pity the poor student ["nyasha"] if that's a typical exam question."
    I was thinking the same thing! The question he actually asked seemed to me rather trivial compared to the full solution of the network.
    "VA = 3.243 V
    VB = 5.270 V
    VC = 0.811 V
    VD = 2.432 V
    VE = VX = 0.270 V"
    Yep. That's what I get, too. I was hoping HGMJR would show us how to do it using Millman's theorem.
    As far as impedances, probably a good way to find them is to attach a 1 amp current source to each node, one at a time, and re-solve the network. Then subtract the voltage at that particular node (without the extra current source) from the voltage there with the 1 amp injected. That difference voltage (divided by 1 amp, of course) should be the impedance.
    I get:
    Z@VA = .5946
    Z@VB = .1622
    Z@VC = .1892
    Z@VD = .4054
    Z@VE = .1622
    You'd think the impedance to ground on top of a voltage source (such as node VC and VD) would be zero, but for a controlled source it's not necessarily so!
  7. kiranag
    Member
    Apr 14, 2009
    12
    From the circuit, the current i(x) is flowing from V(c) to v(a) through the resistor 2ohms. So it can be written as the difference between the voltages divided by the resistor. Hence i(x)=[V(c)-V(a)]/2. Then from the circuit again V(d) is nothing but the negative of voltage of the dependent source 2i(x). but we know what is i(x). Hence V(d) is -[V(c)-V(a)]=V(a)-V(c). Hope you understood this.
  8. The Electrician
    Oct 9, 2007
    2,300
    335
    Well, what do you think, tnk?
    Do those impedances make any sense? Have you tried to calculate them?
