Nodal Analysis questions
Discussion in 'Homework Help' started by Digit0001, Mar 13, 2011.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    The two questions i am having trouble getting the correct equations.
    View attachment tut2qns.doc
    Can someone tell me where is my mistake?
    Question 1
    SuperNode
    5 = i2 + i3 + i4
    Node 1
    i1 = i2 + i6 + i5
    KVL
    6 + V3 - V1 = 0
    Question 2
    For SuperNode
    i1 + i3 + i2 + i - i3 = 0
    For Node V3
    i4 + i3 = i
    For KVL
    2i + V2 + V1 =0
    P.S
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    In question 1 the 3A source to the left side is translated in the circuit to the right as a 6V equivalent source. The equivalent circuit shown on the right is incorrect, as the 6V source should have a series resistance of 2Ω. This is not a supernode example.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    It would have been "nice" if you had acknowledged the fact that you had made a mistake in the schematic attached with your original post, rather than just correcting the problem and leaving my post in no-man's land.
    In any case there are several errors in your equations as well.
    This is the set ...
    i2+i5+i6=5
    i6-i3-i7=0
    i4+i5+i7=0
    i2=V1/4
    i3=V2/2
    i4=(12-V3)/8
    i5=(V1-V3-6)/2
    i6=(V1-V2)/8
    i7=(V2-V3)/4
  4. Digit0001
    Mar 28, 2010
    89
    i have done Question 2 again and these are the equations i get but the answer is incorrect.
    supernode V1-V2
    i1 + i2 + i3 + i4 = 0
    Node V3
    i3 + i4 = i
    KVL Supernode
    2i + V1 - V2 = 0
  5. peter_morley
    Member
    Mar 12, 2011
    179
    Can you make v2 and v3 also a supernode? I am also learning nodal analysis and number 2 is a problem I have never come across...quite a mess.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    This was my attempt at a solution for the second problem. Interesting challenge although I didn't specifically use supernode approach.
  7. The Electrician
    Oct 9, 2007
    2,300
    335
    To solve problem 1, it's better not to convert the 3A current source in parallel with the 2 Ω resistor into a voltage source. Rather, convert the 12 volt source in series with the 8 Ω resistor into a 1.5A current source in parallel with an 8 Ω resistor. Then there is no supernode and a nodal solution is straightforward.
    A supernode solution for problem 2 goes like this:
    All three nodes comprise the supernode, so the three currents from the supernode to ground must add to zero: I1 + I2 + i = 0
    That becomes a nodal equation:
    Eq 1: V1/4 + V2/1 + V3/4 = 0
    The next 2 equations are constraint equations for the two sources:
    Eq 2: V1 - V3 = 12
    Given that 2*i = 2*(V3/4) = V3/2, we have:
    Eq 3: V1 - V2 = V3/2
    Solving these three equations gives us:
    V1 = -3
    V2 = 9/2
    V3 = -15
    Digit0001 and t_n_k like this.
