OK here is the problem: use nodal analysis to find Vo in the circuit at R6. It is supposed to be 7.57v.
wow, your fast, jejejejejjeIf you will post what you have done so far to solve the problem we can help you get past your snag point.
hgmjr
I don't see how they get an answer, either. They only have 4 equations, but there are 5 unknowns. The current Is2 doesn't appear in any of their equations, but surely it has an effect on the solution.this could help. its a solutio to the problem. the solution is so quick that i dont see how they found the answer.
thanks, any other idea or suggestion in how to solve this exercise.I don't see how they get an answer, either. They only have 4 equations, but there are 5 unknowns. The current Is2 doesn't appear in any of their equations, but surely it has an effect on the solution.
Perhaps they got an answer from a solution book.
[ .0025 -.0005 -.001 ]
[ -.0005 .001 0. ]
[ -.001 0. .003 ]
I don't know what you mean by "v1 = 4.2 A"; it looks like you're saying that v1 = 4.2 amps.do you have the answers
I got v1 = 4.2 A & v2 = 16.8
and voltage = 33.6
I want to know if I did it right or not
Thread starter | Similar threads | Forum | Replies | Date |
A | Minor Nodal Analysis Problem-- Why add voltage instead of subtract? | Homework Help | 2 | |
(Superposition/nodal analysis Problem) This solution makes no sense to me | Homework Help | 4 | ||
Nodal analysis problem with supernode | Homework Help | 3 | ||
E | Nodal analysis problem | Homework Help | 5 | |
Nodal analysis problem | Homework Help | 14 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
