Nodal Analysis - No Resistor
Discussion in 'Homework Help' started by p75213, Aug 26, 2011.
  1. p75213
    May 24, 2011
    39
    I am having problems with this circuit. The circuit has 3 nodes - v1,v2 and v3. Solve for the voltage across the 3 ohm resistor using nodal analysis. the 3 equations I get are as follows:
    1) (v1-v3)/6-2+(v1-v2)/4+v1/0=0
    2) (v2-v1)/4+v2/0+(v2-v3)/2=0
    3) (v3-v1)/6+2+(v3-v2)/2+v3/3=0
    This is obviously wrong. The 1st equation has v1/0 and the second equation has v2/0. How do I get rid of them?
    Can somebody help with this please?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Just to clarify your schematic. Is the earth [0V] connected to both the bottom "rung" and the center of the first "rung"?
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    Simply ignore V3
    Write the nodal equation only for V1 and V2
      File size:
      13.9 KB
      63
  4. p75213
    May 24, 2011
    39
    yes it is.
  5. p75213
    May 24, 2011
    39
    Yes it is.
  6. p75213
    May 24, 2011
    39
    Could you clarify please?
  7. p75213
    May 24, 2011
    39
    Is there no current through v3? Ignoring v3 I get:
    1) (v1-v2)/6-2+v1/0=0
    2) (v2-v1)/6+2+v2/3=0
    I still have a divide by 0 in 1). Can v1/0 be replaced by -v2/3?
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    It would be useful for you to re-draw the schematic taking account of which elements are connected to the common [0V] rail. You'll find that apart from the common node there is only one other node.
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    Ok so the diagram look like this
    And we only have one unknown node voltage V1.
      File size:
      13.2 KB
      134
