Nodal Analysis equations
Discussion in 'Homework Help' started by progolfer, Mar 11, 2011.
  1. progolfer
    Mar 8, 2011
    7
    Hi all,
    I am solving the circuit shown in the attachment by nodal analysis, I have already solved it using mesh and thevenins an am now trying to solve using Nodal analysis. I have come up with 3 nodal equations but when solving them iam getting a different answer to that of mesh and thevenins theorems. The 3 nodal equations I have determined are as follows could anyone tell me if I have made a mistake in them. the aim is to calculate the voltage across the 4 ohm resistor which is 2V.
    Node A:
    0 = (-Vb/2) + (17Va/10) - (Vc/2)
    Node B:
    11 = (Vb/2) - (Va/2)
    Node C:
    -5 = (-Va/5) + (9/20 Vc)
  2. Robert.Adams
    Feb 16, 2010
    112
    5
    For Node A: Look at the Vc term. Where does your -1/2 come from
    For Node C: Consider the 4A source feeding into the node, it looks like you forgot it.
  3. progolfer
    Mar 8, 2011
    7
    Sorry I meant to write -1/5 for node A, however I totally missed the fact that the 4A source was affecting node C, thanks for spotting this. The equation for node C should now read:
    Node C: -1 = (-Va/5) + (9/20Vc)
