Hi, i've been posed the following question:
From nodal anlysis i obtained v1=15 v2=v=5 v3=-20
Does that mean v3 is supplying the voltage through the circuit?!? Also could you check to see if those values are correct.
Also how am i supposed to be able to calculate the power associated with the dependant power source. Does the - value mean it is being delivered to the circuit and that and that the 15V power source is actually absorbing the power?
for part c) is the power value 37.5W, and is it being delivered? as it is a positive value?
Any insight into this problem would be much appreciated. Also what is the answers to each section, a) b) c) etc. as i am absolutely stumped.
Regards
Thomas Introna
Regards
Thomas Introna
